humblerb wrote:
Going through this now with a RAM 2500 Short Bed, moving to a RAM 3500 Long Bed.
Patriot Slider is set up on rails in 2500 SB.
The 3500 LB has pucks. BW only makes a puck adapter for the Companion.
BW Rep told me on the phone that Demco makes a frame adapter that the Slider will fit on, but it won't slide, because it sets too high.
If I was using a SB, I would have the rails installed and use the slider.
It costs $1200 to have a new rear window installed and the post repaired. Ask me how I know. UGH.
With a Short Bed, you won't need the Slider.....until you do.
It's really simple! Sell what you have on CL. Now buy the proper hitch for the puck system you have like this.
