prodeville's avatar
prodeville
PULLING 20K OR BETTER
I'm hearing that you really need a MDT or HDT to pull a fifth wheel over 20k. The MDT is expensive and a used HDT is huge. Is there anybody out there pulling that weight with a 3500/4500 or 350/450 with no problem? What about breaking?
I'm looking at A DRV, Augusta or a Continental.
    ".....a used HDT is huge."
    Do you mean the cost - or the physical size?
    A singled HDT will be wider than a standard dually, but depending on the length of the bed (if you add one) -and whether you single short or long - the overall length can be about the same as a dually pickup.....at way less cost than a new pickup.
    So - You won't be *breaking* your bank account.
    And - Power and *braking* will be outstanding.
    In (many) states where the HDT can be registered as a MH, license cost can be less than a new pickup - and only a std DL is needed.
    You won't find owners on here, so suggest you visit the Escapees HDT forum - for some Q & A and info to/from the folks who own one.
    (Knowledgeable folks who won't twist your arm, LOL!)
    Escapees HDT forum
  • 2016 RAM 3500 Dually with 3:73 gear---24K
    2016 RAM 3500 Dually with 4:30 gear---26K
    Sure the other two in 350 Dually are similar
