Cummins12V98
Aug 24, 2014Explorer III
garysol wrote:Cummins12V98 wrote:
If I were you I would look at the Curt and PullRite next to the B&W. B&W is very conservative in their ratings. I am over a bit with my 18K B&W and would have it over any other hitch.
So you would rather have your B&W with a lower rating than a Pullrite. Can you tell me why? What makes your B&W better than a Pullrite that would not be overrated in this situation? I am not looking to be argumentative just wondering what makes the Pullrite inferior.
I have talked to B&W "off the record" and asked why they had lower ratings compared to others hitches. They prefer to have a larger margin of safety built in. As I said compare them side by side.
For one thing look how the head sits into the U shaped saddle on the PullRite. Hot as solid or noise free as the B&W. B&W head to base is a solid rubber precision fit noise free connection.
Look at the locking handle and complexity of the PullRite and then look at the simple no questions asked if I am hitches locking system on the B&W with the solid steel1" thick fully enclosed jaws.
I am not saying PullRite is a bad product, I would own one if I had a short bed and needed a slider.
Bottom line do as you wish. But at least LOOK at the B&W.
If you are towing a 20K 5er there is no problem. IMHO a couple thousand heavier would not be either but at 20K you are probably at your trucks max or close anyway.
Any engineered quality product has a huge safety margin factored in. It just is not going to break at 20,001 #'s.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
