Cummins12V98
Aug 24, 2014Explorer III
calewjohnson wrote:Cummins12V98 wrote:garysol wrote:Cummins12V98 wrote:
If I were you I would look at the Curt and PullRite next to the B&W. B&W is very conservative in their ratings. I am over a bit with my 18K B&W and would have it over any other hitch.
So you would rather have your B&W with a lower rating than a Pullrite. Can you tell me why? What makes your B&W better than a Pullrite that would not be overrated in this situation? I am not looking to be argumentative just wondering what makes the Pullrite inferior.
I have talked to B&W "off the record" and asked why they had lower ratings compared to others hitches. They prefer to have a larger margin of safety built in. As I said compare them side by side.
For one thing look how the head sits into the U shaped saddle on the PullRite. Hot as solid or noise free as the B&W. B&W head to base is a solid rubber precision fit noise free connection.
Look at the locking handle and complexity of the PullRite and then look at the simple no questions asked if I am hitches locking system on the B&W with the solid steel1" thick fully enclosed jaws.
I am not saying PullRite is a bad product, I would own one if I had a short bed and needed a slider.
Bottom line do as you wish. But at least LOOK at the B&W.
If you are towing a 20K 5er there is no problem. IMHO a couple thousand heavier would not be either but at 20K you are probably at your trucks max or close anyway.
Any engineered quality product has a huge safety margin factored in. It just is not going to break at 20,001 #'s.
Talking with B&W offline is great. I have a family and a lot to lose if i get into an accident pulling more than it is rated for... I can only assume B&W will not be there in court testifying in your defense.
I agree with your comments. I as you have the right to express opinions and buy and use what we choose.
Using your head based on actual life experiences will give you knowledge and you can do what you want based on your experiences. Do you believe Craftsman when they say their Shop Vac develops 6HP? I don't, I also don't believe the claims of some of the Chicom junk in this country like floor jacks that say 3 ton capacity when I have a Quality US Made Jack that is so much more robust but only is rated at two tons.
I will stick with a lesser rated product I know is far superior.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
