kemer
May 07, 2013Explorer
Pump Question
Just bought first 5th wheel...2002 Keystone Montana. Had the intro briefing from service tech, but can't remember everything. On the monitoring panel, there is a switch for heater and pump. I understand the heater is water heater unit. But can't remember the pump function. If I hook up to city water via hose to unit, do I need to run pump? Also, when dumping black/grey water, should I run pump?
I'm thinking that if I'm using only the fresh water tank, I need the pump on. Is that correct? Thanks for answering.....
