djgodden's avatar
djgodden
Putting Fuses in a Solar System
According to the Renogy installation diagram there should be a fuse on the positive side between the solar panels and the charge controller, another between the charge controller and the battery, and another between the inverter and battery.
My question is about 2 going to the charge controller. The instructions show they are the same size. The calculation is # of panels x panel Isc x 1.2 (4 x 5.75 x 1.2). For my system this comes to 27.6.
Can I round up to 30?
What kind of fuse should go in there? I see ANL and AGU, does it matter which?
Where do I find a quality inline fuse holder for 4 AWG? Amazon has several but they are plastic... does that matter? Any negative comments about plastic fuse holders?
  • I'm installing a GoPower 160 watt panel today. I already have an inverter. Yes, there is quite a hefty fuse between the inverter and the batteries. GoPower does not show a fuse between the panel and controller but only the controller and batteries and for this panel it is a 30 amp fuse. I'll be curious what others say. Thanks.
