cummins2014
Jun 06, 2016Explorer
Nevadastars wrote:Durb wrote:
The rails are the least of your concern. Check below the bed and see if your frame brackets are there. If the seller took those then you have an increased expense and installation costs. Curt rails do not come with fastening bolts, they come with the frame brackets. My bolts were carriage style bolts (smooth round head). The ones you buy from a hardware store are soft and may not be suitable for the rail application. I would check with Curt customer service to see if they use special fasteners. When I bought my Curt frame brackets they did not specify that they work only with Curt rails (as I remember).
The rear brackets are there, but not in the front. In fact it looks like it never had brackets in front which I thought was odd. There are no marks on the frame where they would have been. I recently retired from working on cars and trucks as a body tech by trade for over 40 years, so installing it should be no problem once I have everything I need. Like I said, my biggest issue is I did not want to add more holes into the floor and will do my research to find exactly how it should be properly mounted.
Here is a measurement you can check from the eight holes you have in the bed. This spacing is used on MOST conventional hitches that use in the bed bed rails , and that is 22". So from front to back on either side from the center of the forward holes to the center of the two rear holes should be 22" . Find the center between these two sets of holes either side, and they should be the 22". Hope that makes sense.
About Fifth Wheel Group
19,008 PostsLatest Activity: Mar 07, 2025
