- We chose a wall mount bracket which allows the TV to be removed easily. Taking it down and stowing it snugly beside the bed takes only a minute or so and leaves it nicely protected for travel, and the travel stress on the wall is a lot less.
- You might run a pair of 1x2's down the wall to rest the weight on the cabinet below. That would also give you a mount for a small DVD shelf under the TV.
- There surely is a frame member at the edge of the door and at the bedroom window. If you span the entire distance with a support board you could add pegs to the exposed ends for coats, flashlight, keys etc.
