Vulcaneer
Oct 27, 2013Explorer
Oh! You dropped out both axles? How you gunna make sure your axles are aligned perpendicular to the kingpin? Lots of people make that mistake. Now you have to bolt everything up and hope for the best. Maybe try the string method to get you close. But get to a good alignment shop ASAP. BE SURE TO DO THAT.
As for the bolts, torque them according to the bolt spec's. Be sure to check the Bolts grade before checking the spec's. Grade 5 have a different spec than a grade 8.
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 24, 2025
