Old-Biscuit
Jan 17, 2014Explorer III
Don't know about having to remove all that just to adjust the slide but if that what you want to do.......
Remove all trim......some is double stick adhesive and some have lips that go into metal track.
Then remove all screws holding metal tract
Then remove screws holding panel in place
Then use a utility knife to cut caulking
Pull overhang panel down and pull it out
Then for front storage you will have to remove the screws that go thru support blocks from inside via compartment door
Disconnect any wiring attached to front wall
Remove trim/tract and screws running vertical holding front panel to sidewall
Sounds like a really bad design IF the front overhang/front wall have to be removed just for an adjustment
My bedroom slide is adjusted by lifting up bed to get to storage area then lifting out the floor panels in storage compartment where the motor and slide support/rails are.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
