- Dave_H_MExplorer II
bucky wrote:
Horsepower and torque being equal, a gasser works no harder than a diesel. The difference is the RPM where the sweet spot occurs.
Buckey, glad you only posted a one sentence reply, since you are wasting your breath. :R
I been wondering how that beast is gonna turn out also. As I think I understand it will also have an 8 speed tranny behind it. - ford_coupeExplorerbeen towing 3 different 5'ers w/2003 3500 drw only problem is you lose speed going up hills,ya just adjust your right foot a little. 100,00 miles on my 2003 no problems.newest 5'er is 38' long combine weight about 17000#
- buckyExplorer IIHorsepower and torque being equal, a gasser works no harder than a diesel. The difference is the RPM where the sweet spot occurs.
- Dandy_DanExplorerMRE I pull the trailer in my signature with a 5.7 Hemi and 3.73 gears. I cant see why you would have struggles with the 6.4 but would depend on the rear end. I don't think twice about taking ours most anywhere although just a little higher gear would be better (3.90's) W have pulled ours over 25000 miles on trips from home to Albequerque, down I-75 and I-77 (W. Va. turnpike) to Florida. You will get a lot of different ideas by the weight police but make your own decision. Good Luck and Happy Camping.
- john_betExplorer II
donn0128 wrote:
This is not personal use experience with the motor he ask about. It is only an opinion.
Sure it does. Gas motors tend to have far less towing capacity than diesels. If your considering towing a 10000 GVWR fifth wheel, and strictly speaking you will have no problems. Now if you are asking if the 6.4L hemi will haul the load easily, that is an entirely different question. A gas motor is going to have to work far harder towing the same load. Flat lands you wont feel much difference, but when you get to the hills/mountains your gas motor will be screaming up the hills, where a diesel will simply roll right over the hill. IMHO a 6L gas motor is going to be about maxed out at 10,000 pound load. - Dannyabear1ExplorerHemi is a name tag; Real Hemis were discontinued around 1978
- donn0128Explorer IISure it does. Gas motors tend to have far less towing capacity than diesels. If your considering towing a 10000 GVWR fifth wheel, and strictly speaking you will have no problems. Now if you are asking if the 6.4L hemi will haul the load easily, that is an entirely different question. A gas motor is going to have to work far harder towing the same load. Flat lands you wont feel much difference, but when you get to the hills/mountains your gas motor will be screaming up the hills, where a diesel will simply roll right over the hill. IMHO a 6L gas motor is going to be about maxed out at 10,000 pound load.
- M_R_E_ExplorerMy trailer weight is about 10,000lbs loaded. But that has no bearing to the question.
- donn0128Explorer IIWhat size fifth wheel?
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 27, 2025
