I have a prime time fury 2910. When I loan my load or unload my can am Spyder the angle of the ramp is to steep and the bike hangs up. Any simple tip to stop this?
Several simple things can be done: - As mentioned a few boards under the ramp. - If you can park where the ground is sloping up would do a similar trick - Alternatively, you could raise the front which will drop the back. - If you back into the garage, just gun it...ooops sounds fun but maybe not the best idea.
