topfuelmotorspo
Jul 22, 2013Explorer
fsujeeper wrote:
The leak is most likely due to the slide itself. I would make sure the slide is aligned properly and no longer leaking. i would also make sure everything on the roof is good, water can travel inside the roof and run on framing to a low point. The framing is also aluminum, so no rot there.
We have the same camper, same year, same model, just not with the velocity package. We love it, and it has been good to us. The only issue we had was with a tire blowing and ripping the skirting off of the raptor. We just upgraded to 17.5 tires to get rid of that problem.
mark
I am thinking there is no major issues and that the slide may need to just be adjusted. I was more concerned that there were structural issues with the coach. It does look like the same set up i had on my 2006 Raptor which means there are plenty of them out there working well with no problems. Are the slides easy to adjust if needed?
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 20, 2026
