djousma wrote:
Fulltimer50 wrote:
The jacks on my rig are set at a 5* angle by design. Unless yours is bent more than that, I would not worry about it.
Mine are two, but outwards, for stability I presume. I expect that the OP's is bent forwards from backing into something. OP also doesn't say what part is bent. Since it was most likely fully retracted, the piston probably isn't bent. Could you possibly just loosen the bolts that attach it to the frame, and just see if it moved vs actually got bent?
Yes, it is bent forward toward the rear tire from backing into the edge of our driveway. Piston comes out just fine. The black tube is welded to the bracket with two plates and it's the plates that bent. I'll probably just replace it myself. It's a $434 part.
