Mmaxed
Jan 05, 2023Explorer II
dsrace wrote:Mmaxed wrote:
It sure sounds like you are light on tongue weight now. As you said a fifth wheel/goose neck should have 25% of the weight on the pin. If you are light now, how will you ever have the weight you need with the conversion? A fiver with too light pin weight is just as bad as a bumper pull.
so the GN conversion would all but remove sway,
That is not true in all cases. Twice I have pulled goose neck flat beds that had too light of tongue weight. Got plumb scary over about 50 mph, until we stopped and shifted some cargo forward. My point is that if too little tongue weight is your problem now, the goose neck conversion may not fix it. Start my knowing your current weights.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
