opnspaces wrote:
Been there 2 times with a very similar window on my TT. Number one thing to do right now is to get a roll of tape (Blue masking or clear box tape) and carefully tape up as much as you can to keep the broken glass in place before it all falls out and makes a huge mess.
Once taped up take the one screw out and take the window to a glass shop that does windows and doors and such. They will measure and have the replacement cut and tempered and replaced in your existing frame.
One caveat that I did not know and learned the hard way. Keep the replacement glass standing vertical like it sits when installed in the trailer. If you lay it down flat it might break overnight.
Thanks, already used blue painters tape to tape the whole window. Good to go there. Good tip on transporting it back in the vertical position, I wouldn't have thought about that.
Found a local glass company, she doesn't carry tinted tempered but can get it and said she would rig me up with a temporary solution until she got it.
Thanks for all the input!!
