NemesisR6
Dec 06, 2016Explorer
twvette wrote:It might just be a matter of slightly adjusting the door latch "catch" on the door frame.
Picked up new Fuzion 420 fifth wheel and when it is on ground both of our two bedroom and bathroom hinged doors will stay closed. When hitched on truck it seems to be flexing and doors wont close so has some flex. These two doors are next to each other in front. Its not that the doors rub on the door frame and wont close into the frame, just the knob latch wont engage properly to latch. My previous Weekend Warrior had only one hinged door but did not have this issue. How concerned should I be or is this common and just need a slight adjust on the door handle latch.
The deadbolt on my 8.5x20 side entrance door is fine when parked, but when towing with the WD hitch installed the frame flexes juuuuuuuust enough to cause the deadbolt to hit the bottom border of the catch.
Took a dremel to the catch on the bottom and took just a little over a hair-width off and it locks perfectly now in any condition.
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
