grizzly660fan
Dec 06, 2013Explorer
micahmiles wrote:
I've also found that keeping the slide seals lubricated and spraying a non sticky silicone spray on the slide tracks seems to help keep things moving easily.
Yes, this is GREAT advice! Also spray the silicone spray along the thick rubber sweep under each slide. Try to get the silicone spray on both the inside and outside of this sweep. Don't forget to spray the u shaped portion under each of the metal tracks where the rollers go.
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 18, 2025
