Mighty_Thor
May 09, 2014Explorer
dougrainer wrote:ScottG wrote:
Nice work, I've never even heard of repairing a valve like that!
Scott
You can rebuild but NO shop or service center ever would. Liability and the fact that Gas valves are NOT to be repaired- replace only. But, if you want, like the OP, rebuild it. Just understand the risks. I would never allow a friend or family to use a rebuilt gas valve. I value them. Doug
I have to respectfully disagree. First, if it was not meant to be rebuilt they would have constructed it in such a way that it could not be easily disassembled. Also, If your not supposed to rebuild them why do they sell the grease to do it with. Once the grease is in place assuming the valve is not damaged it works very simply. turned one way the gas flows through the holes turned the other way the gas does not pass through. This is on the low pressure side of everything, and assuming that you check for leaks, as I did periodically) there is little or no danger. This valve is not like on a stove where it is used often and in multiple positions. On the fridge, it is on or off. But, If you have a couple of grand for a new fridge, you might want to replace rather than repair.
About Fifth Wheel Group
19,031 PostsLatest Activity: Apr 14, 2024
