jbeletti
Aug 17, 2014Explorer
Hi Rick,
Are you seeing any water leaking from the underbelly? I think you're on the right track. Sounds like the pump cannot get primed from the fresh water tank. Wonder if there's a cut in the line where the pump is drawing air through and therefore can't pull the heavier water??
The water pickup should be a connection on one end of the tank about an inch from the bottom. You should be able to drop the underbelly, tape a new line onto the old and pull it up to behind the UDC.
Best of luck my friend.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
