donn0128
Oct 01, 2017Explorer II
Re: Lead Landing Leg not working
No need to shop a third party vendor. Go right to the mfg web site. Likely the pin that holds the bevel gear has sheared or the bevel gear has broken a tooth. Both are an easy fix. If there is a metal cap on top of the leg, pop it off. On the underside will be all the information you need to get repair parts.
