Tireman9,
In my hurry to make it to the tire shop before they closed I failed to take any pictures of the tire.  I wish now that I had.  Basically, the only thing left intact was the beads.  There was no tread remaining at all.  There were pieces of nylon with some loose casing parts attached between the beads - that is all.  The picture you have above has more remaining tire than what I had.
I checked the tire pressures before departure that day (like always) and it was fine.  (75 psi.  Why? Tire rated for 80 psi, wheel rated for 75 psi.)
At this time I am investigating TPMS brands and models.
Kevin
