dustycoyote
Mar 18, 2016Explorer
Still just a best guess but here are some real world numbers from the CAT scale.
I believe that my rear axle weight (unhitched truck with me and a dog in it, half a tank of gas, if I remember correctly) was about 3K.
Published pin weight of the trailer online is 3066 lbs. I have the Onan 5500 installed on mine though so I recognize it would be higher than the published number.
My actual weights from the scales;
new camper, no stuff loaded up yet,
Steer axle - 4620
Drive axle - 6380
Trailer axle - 9700
camper loaded up including an ATV in back & 1/4 tank of fresh,
Steer axle - 4660
Drive axle - 6300
Trailer axle - 11300
My tire ratings on my truck are 6396 lbs for either axle, so I'm getting pretty close to maxing my tire ratings... Concerned to see what the pin weight is if I travel with full fresh tank. Most on the forums have said that it shouldn't add a lot to the pin weight because it sits close to the trailer axle though, Will have to check next time I plan to dry camp.
Steer axle - 4620
Drive axle - 6380
Trailer axle - 9700
Steer axle - 4660
Drive axle - 6300
About Fifth Wheel Group
19,010 PostsLatest Activity: Mar 31, 2025
