el_Rojo
Oct 11, 2013Explorer
This will probably take 2 people, but put a voltage meter on the battery and check the voltage when you hit the slide button. If it goes below 11 volts the battery doesn't have enough charge to operate the slide. If it goes to zero you probably have a short in the battery.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
