nu2this2
Nov 11, 2017Explorer
Mike LeClair wrote:
I would be inclined to start at the vehicle plug and test for 12V current on the brake wire output. It seems to me that the wiring in the TV plug can be "fragile" and subject to become damaged from a sudden jarring. Next up would be to check the continuity of the brake wire in the RV harness by using a tester, one probe in the kink pin box and the other on the appropriate pin of the harness. Good Luck
Cheers!
Mike
Thanks Mike,
When you say "TV"plug, is that the trailer vehicle your referring to? If so, I don't have a plug just a bunch of wires in what I call a junction box inside the kingpin housing assembly. Do you know what color the brake wire would be?
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
