Re: Toilet bowl doesn't hold water
Use rubber gloves, and soak a cloth in a little dish soap. Open the bowl and clean both sides of the gasket,rinse with water and use dry cloth to wipe again,then add a little vasalean to the rubber gasket,wipe inside and outside of gasket and give it a try. If still leaks a new gasket may be needed.
No RepliesBe the first to reply
