Re: Truck stops.
1. Put your credit card in the slot on the pump
2. Remove the nozzle (if you have a diesel make sute you put the green nozzle in the filler
3. Turn on the pump
4. Fill your tank
5. Replace the nozzle when the tank is full
6. Get a receipt (if you want otne)
7. Pull away from the pump and motor om...
Options:
If you have a propane fridge, extinguish the pilot light before pumping fuel, especially if the fuel is gasoline and not diesel
If you want to pay inside, push the pay inside button and pay the lady when done fueling.
No RepliesBe the first to reply
