I want to use the quick connect on the FW. I bought a hose but the fitting is for the regulator and I know you have to remove the regulator on the grill because it is already done for the 30# bottles,...
Could I assume your weber Q is the model 1200? Is your grill set-up to accept the screw-on green propane containers? I have the model 1200 grill and it can only be used with disposable cylinders. Unless I'm wrong. If Iam, I stand corrected. Although, I like using the disposable cylinders because otherwise I'm tethered to a rubber hose from my camper. Now I can set the grill anywhere I want. Just my thoughts.
