2-MTnesters
Dec 01, 2013Explorer
Re: Wheel/Brake/Bearing Question
My opinion you have worn bearings. I would highly advise that you pull each wheel and inspect both inner and outer bearings and replace as necessary. I would also highly advise NOT using the EZ-lube system as its very easy to over grease and blow out the seal. If you do choose to continue using the EZ-lube system, you should rotate the wheel in the forward direction while pumping in the grease. This will help to evenly disperse the grease in the bearings.
