e-light
Jun 29, 2015Explorer
Calicajun wrote:
Does the Andersen work well with a 6'4" bed.
Works perfect on mine...probably depends on the front cap of your 5er. If you have a newer model with the rounded front cap, you will probably be fine. I can go to full 90 degrees with mine.
The pluses for the Andersen, it's light (Aluminum), dead simple to install and remove, works with any gooseneck ball, NO PLAY, greaseless...its the only hitch I'll use from now on.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
