Cummins12V98
Jun 30, 2015Explorer III
jerem0621 wrote:Learjet wrote:
I spoke with Curt tech support today, and they confirmed that 1/4 " is about a normal slack tolerance with the jaws around the pin.
Sounds like you have the slide bar model of the Curt 16k hitch.
It's VERY secure...if the bar is across the pin in the back...you are locked in. The down side is that there is some slop with a slide bar hitch. If it is the Slide bar version there should be a tension rod at the back of the hitch head that is supposed to take some of the slop out.
Thanks!
Jeremiah
The slide bars can break, my Dad's did on his RBW. They are noisy. I had a RBW also and cringed everytime I stopped or took off!
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
