mtofell1
Jul 20, 2020Explorer
The 6084# is likely due to the pizza cutter stock tires. The axle itself is likely rated much higher. Check part numbers and it may be the same rear axle on the 3500 SRW for that year. I'm not advocating exceeding this rating but if you can determine the axle rating is higher and you get some higher rated tires I'd have no problem running right up to the axle limit.
Aside from your question, hang onto that 06 Duramax as long as you can. I ran that exact truck for a glorious 5+ years and still kick myself at times for selling it. That's one of the best diesels ever made.
About Fifth Wheel Group
