kroghville
May 15, 2014Explorer
Ralph, I recommend you take a 12 volt tester and see if you have power at the fixture before you go through the work of cleaning all the fixtures. If you have power, then by all means make sure the fixture contact areas are clean. A small shot of WD-40 would be appropriate at this time. If all of your lights quit working,I suspect a fuse,wiring, or connector problem.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
