GasmanExplorerSep 29, 2013Reese AirborneWill be installing Reese Airborne pin box on our 5th and was wondering how to measure to keep the ride height the same as it is with the fixed pin box. I know that I can mount it and measure but is th...Show More
craig7hNomad IISep 30, 2013When I installed mine had there were not enough bolt holes to make adjustment. After install the height was close to orignal height.Your ride is adjusted by the air in the bag. There is a line on the shock that will tell you the amount of air needed.question for allygerry; how did you hook air to the bag from your truck?
Related ContentReese Airborne Sidewinder and Skid Plate LubricationSidewinder 5th AirborneReese WDH5th Airborne PressureReese Sidewinder
