I have owned both a Durango 1500 series and Cougar 327RES. Both worked great for us. Here are some things we noticed with the lite unit.
- Walls are thinner... which means less insulation
- The framing was based on the box configuration vs. having evenly spaced wall studs. I.E: framing around the perimeter of the box, around the door but then large gaps between studs
- limited amount of pull outs and the pull outs were not as deep
- some models have less hanging cupboard space as the walls have less framing
- oven was small... although the stove surface had three burner.. the oven interior height was shallow and would not fit standard cooking pots restricting its use.
- and my PET PEAVE the electric awning was anchored in the wall skin only and not in a stud.... first year we were caught in a freek storm which tor the awning arm away from the wall... this compromised the awning reducing it to a fair weather awning going forward.
My 2c worth... good luck.
GPG
