fj12ryder
Jan 24, 2023Explorer III
Yes, the fluid just circulates between the slide pistons and the jack pistons. Where the pressurized fluid goes is determined by the solenoid valves opening and closing hydraulic valves directing the pressurized fluid from the hydraulic pump.
Actually the level should vary as the slides go in or out. The volume is going to be less for the slide pistons, so it may not be as noticeable.
About Fifth Wheel Group
