phil-t
Jan 24, 2023Explorer
dedmiston wrote:
Is the fluid for the slides just recirculating then? Why isn't the level in the reservoir affected when I run the slides in and out like it is with the jacks?
Likely, the level varies with jack deployment because they are pressure out (oil pumped into the jack cylinder), lowering oil in the reservoir; and spring return, raising the oil level. Slides are double-acting cylinders - (oil s pumped into one end to deploy, while the oil is pushed from the other end of that cylinder; opposit for retract. Thus the oil level does not change for the slides.
Slide Cylinders are like this
About Fifth Wheel Group
