americanrascal's avatar
Apr 19, 2014
Removing 5th wheel Hitch from pick up bed
Any good ideas on how to easily pull the hitch out of the truck bed so I can use truck for other activity?
I need to temporarily remove my Reese 16K tube slider. I know to release it from the rails I only need to pull the 4 cross rail pins, but any ideas on how to get it easily out? (If that's possible). I'am thinking using a pulley to the beam in garage ceiling, then lower the hitch assembly to dolly on floor after truck is pulled away.(Would have to find a pulley system)
I was advised the hitch weighs about 180 lbs??? I'm good- but not that good!
I have also read that some simply hook it to the king pin on the trailer, then pull the pins and drive off leaving it hanging from the trailer king pin. I worry that would put some significant downward strain on the pin and then I would have to find some way to lower it to a dolly or ground level.
Mamma has assured me she will contribute no effort to this exercise other than to laugh at me during the process- shes good at that --and my Geritol tonic says on the label I should never strain myself! So I got to figure this one out. Help!
I suppose there is no way to train a hitch to simply step out of the bed on to the garage floor huh?
