Eyetattoo
Jun 17, 2013Explorer
Removing caulking?
What do you all use to remove old caulking on the fiberglass gel coat? Normally I would use a flat razor blade but not sure if that is a good idea on the fiberglass? Also is there a solution that softens it up to make is a little easier to remove? Thanks!
