mr__ed
Jun 29, 2014Explorer
weakknees wrote:
A small piece of Eternabond tape might fix you up.
I was thinking of that, too. I have a large amount of Eternabond with me and all I need is a tiny piece for that hole. Of course, the color won't match since the tape is white and the rubber wiper is black but in that location it won't be noticed. I figured using the inner tube repair process may work a little better since the repair may be more flexible than with Eternabond. That wiper does see quite a bit of movement during operation of the slide-out. Another problem could arise if for some reason the Eternabond fix turns out to be not flexible enough. It would cause more damage to the rubber wiper if I tried removing the tape. Perhaps the best thing to do is go with the inner tube repair process first and see if that works sufficiently. Thanks for the suggestion, though.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
