Usnthedog
Jul 01, 2019Explorer
mtofell1 wrote:
Are you sure it's not just the cross bar that feeds power from the motor to the other side? A super common failure is the bolt in the cross bar. It's actually a planned failure point. I carry spare bolts just in case.
I was looking on etrailer recently and seem to remember you could buy an entire setup - jacks, motor and hardware for a few hundred dollars so hopefully this won't cost a fortune if you do need some/all of the parts replaced.
Sorry, I don't know of anyone in that area.
No. It appears that the bearing holding the verticle shaft(the acme threaded rod) failed and allowed the shaft to rub on the housing. Wore enough to weaken the shaft and it sheared off. I have the driven bevel gear in my hand witk a piece of shaft. I wish you were right.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
