Retired_404ExplorerOct 17, 2022Replacement of Suburban water heater...Replacing a Suburban water hater (SW12DE). Removing and replacing seemed pretty straight forward, however... Upon removing the old unit, there were four wires that had to be disconnected from the RV i...Show More
Retired_404ExplorerOct 20, 2022https://parts.unitedrv.com/products/nautilus-series-water-heater-on-off-switch-suburban-white
Related ContentSuburban SW12DEL Water Heater On/OFF switch melts???Replace insulation inside heater column.Water Heater Replacement RecommendationsSuburban water heater replacementSuburban water heater replacement issue
