troubledwaters
Mar 13, 2019Nomad
Use a thin and flexible material like Luan, stain it and put on a polyurethane finish. But even still, you are probably going to want to use colored screws and washers to fasten it to the curve. I've used screws with caps on them also in similar applications. You can use narrow shallow cuts in the back also to make it more bendable like someone mentioned above.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
