RED regulator on off side cylinder is a single stage 30# regulator.........they have been an issue.
They reduce cylinder pressure down to 30# before feeding it across to main 2 stage regulator.
Pigtails have a excess flow check valve---ball bearing style that closes off if pressure on both sides of ball are not equal.
They have been an issue with gumming up and sticking close.
Main 2 stage regulator takes cylinder/high line pressure and reduces it to 0.4 psi (11" WC) to feed propane system.
There have been issues with them.
Which one is causing your problem.......
Hard to tell via internet.
You need to swap cylinders around, try different set ups to eliminate issue
OR throw parts at it.......RED regulator first.
