Cummins12V98
Apr 03, 2022Explorer III
Before completing reading your post I was going to tell you to bleed the brakes.
Simply put there is NOTHING that compares to the MORryde IS with disk brakes.
BurbMan said: "The last time I checked none of the OEM controller supported electric-over-hydraulic."
HMMM, your 2015 RAM should be able to select EOH if you have the factory controller. I can select heavy or light Electric and the same in EOH on my 2015 RAM.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
