Cummins12V98
Apr 12, 2022Explorer III
time2roll wrote:Cummins12V98 wrote:There is also an extra capacity reservoir kit.time2roll wrote:
I found bleeding to be a bit tedious due to the small reservoir. The pump makes quick work of it as long as it does not go empty.
What pump does MorRyde use? After my research I bought a Hydrastar and it has excellent response to the P3 controller.
MORryde uses the Largest HydraStar.
https://www.etrailer.com/dept-pg-Accessories_and_Parts-sf-Brake_Actuator-pt-Reservoir_Retro_Kit.aspx
Good info, thanks. But IMHO not needed as long as you check level every few trips. You will get an idea how often based on consumption.
About Fifth Wheel Group
