Cummins12V98
Apr 12, 2022Explorer III
time2roll wrote:Cummins12V98 wrote:Yes I assume just for convenience. AFAIK if the reservoir is low, the pads are in need of replacement. No fluid should be consumed or lost. Maybe a 3 or 4 axle trailer could need some additional reserve.
Good info, thanks. But IMHO not needed as long as you check level every few trips. You will get an idea how often based on consumption.
Don't "assume" as the fluid will go down as the pads get thinner. So check for sure!
About Fifth Wheel Group
