Chuck___'s avatar
Chuck___
Roof Care and Maintenance suggestions. SEE Finally Update NEED HELP!
I have a 2010 DRV and the roof looks like it is peeling off in some areas. This is a thin layer the thickness of paper or less. Possibly the previous owner put a coating on the roof??? Noticed the peeling in the front corners and some in the far back roof area. Also the roof looks like it has small spots of black mold on top of the roof. Been cleaning the roof with DAWN each year and using a product called Best Rubber Roof cleaner & protectant with UV blocker. I did try using a mixture of bleach and water to clean and kill mold with no luck. Just kind of looks ugly having the black spots on the roof. I called the manufacture of the trailer back in 2017 for maintenance suggestions and was of really no big help other than just wash the roof with with DAWN. I store the trailer outside year around with a cover on it.
Any suggestions? What should I do?
Update as of Oct 6,2020
Called Mobile Suit and asked them about my roof. Mobile Suit RV. DRV recommend calling the roof manufacturer Dicor at 574-264-2699. They might have a higher grade of products for roofs and other RV maintenance products than Henry's. . Wanting for a response.
Just got the phone with an RV retailer/repair shop in Salem, Oregon that has been here for 30 plus years. They said if you maintain a RV roof you should not have to do anything but clean it each year. Said this;if a roof starts to peel, the entire roof needs the peeling remove and completely re-coated. Doesn't sound like a fun job. Also, once this is done, you will have to re-coat the roof about ever 5 to 6 years.
Called an Authorized Mobile Suit Dealer in Oregon today also and they said that they never re-coat any RV roofs and do not recommend it. When the roof leaks of goes bad they replace it. Don't seem like their into doing any real roof repair. Maybe just a very small roof repairs if any and they said to use Dicor product only.
You would think there is straight forward information on RV roof maintenance from the professionals. All I got so far is no homeowner should ever re-coat a RV roof. But Wait! Yes sir you can bring your RV into a dealer and spend thousand to have a new roof put on. Sound like a run around to me!
Finally 10-7-20 : Got in touch with the factory rep from Dicor Products. He told me that within the last couple of weeks several people have call in about questions using Henry's products. His company has a policy about bad mouthing other companies. But; He said that Dicor Roofing System is a two stage process. First step process helps the coating to attach to the final/ second process coating. Rep said Dicor is good for approximately 6 years, Just got off the phone with the Henry's Rep. He said their roofing product is good for approximately 15 to 20 years plus.
So is Henry's Roof coating better of is Dicor Roof Coating?
At this time I do not know the best way to go. Need all the help I can get.
