Thumb
Sep 11, 2015Explorer
RetiredSquid wrote:
Appreciate answers, so next question is if i buy a new portable generator what should i look for. Unfortunately if I want water from my well on my boondock property in northern michigan I need 220v.
There are charts available where generators are sold to size your generator to the total existing wattage you need to operate plus give you the additional temp startup wattage to get your appliances running
Very important that these charts are consulted
Is your well pump a submersible or above ground pump?
Normally, above ground pump motors less than 2 hp can be wired for either 115/230 volt operation
Submersible pump motors are normally 230 v only
About Fifth Wheel Group
19,041 PostsLatest Activity: Apr 16, 2026
