Last fall, I installed a set of Sailun tires on my Montana, upgrading to G rated tires. I’m running only 90-95 pounds in the tires. They are shaking the camper quite a bit. Last week, we cravked th...
No, my trailer doesn't shake itself to death. I run E rated truck tires and keep the PSI at 70. My take on it is the excessively high air pressure in those G rated tires is causing the tire to act like it's made of solid rubber. With no flex in the tire of course it's going to bounce around. Let out some air.
